I see it even from here.
Am I doing it the wrong way?
Yes, thatās what I want, but I canāt seem to get it this way. How did you do that?
Zoom to i7 and you will see it too.
Oh I see, now I havenāt excluded it anymore, it shows! Thank you very much. This tool is so helpful!
I downloaded version:valentina_0.5.0a-20170403142807_64bit-OSX.dmg an I canāt find the passmark. Am I doing something wrong?
Probably.
The passmark feature is part of Detailās Preference dialog.
I have tested the passmark feature and so far it has worked fine. The new add point feature comes also in to real use, because I need to add new points for the passmarks. It also works fine.
I would like to have the passmark a bit thicker line (1,5-2 times) and in 1 cm seam at least 5 mm long. In real printout the marks are a bit too small.
Great and long waited tool. Thanks
Current length is 25% from seam allowance width. Do you want 50%?
Yes, I would prefer 50 %.
When Iām cutting the fabric, I cut through the passmark on the paper as well. After few cuts the short passmark will vanish. Normally the cut is 3-4 mm. The 5 mm passmark will not disappear.
Yes, 50% would be good. Thanks.
This is old version. Are you sure you have right version?
I just checked second time. You are definitely somewhere in your system has old version and run it instead of new.
Thank you, I deleted everything I had and installed it again and now I can see it.
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
