Registation Marks in Seamly2D Pattern File
Hi all and “Happy Pfingsten / Pentecost“ to all those celebrating …
I am a ‘heathen’ and therefore not bound to religious festivals :thinking: :roll_eyes: .. But, to my query today: ‘Is there a way to include registration marks into a pattern (draft) prior to exporting to .SVG / .PDF?’ The pieces I need to cut are right on the edge of my cutting area : 100 X 57 cm. without being able to relocate the material (and the projected pattern), the piece(s) cannot be cut properly.
I envisage a number - four minimum to maintain orientation - of ‘+’ (crossing lines) at 50 mm intervals. I can create these with the current ‘tool-kit’ but I have no idea how to include these into a ‘New Piece’ from the draft pattern. I can of course use my PDF or vector editing tools, but this entails more workflow steps if / when a Draft is altered and exported. . . Any ideas out there ??
Best regards,
David D.
OK, I think I’ve got it now … Adding internal paths … nice tool!
Any supplementary info / opinions would still be gratefully received.
:hugs:
Not sure if this addresses your issue. You could create a pattern piece without SA, the size of your cutting area… 100 x 57… then in Piece Mode manually place your pattern pieces inside the cutting piece. When you export you will have a bounding box of all the pieces.
Hmm :thinking: … not sure if I understand your drift … can you perhaps clarify? …
Unless you mean that I create a ‘dummy’ piece the size of my cutting mat and then add the actual pieces within the ‘bounding box’ … :thinking:
… my issue was (and has been assigned to the sewing scrap-box anyway) that there was one single piece that was large enough to exceed the cutting area boundary. The correct resolution would be to increase the size of the mat (working on that!) and then the ability to create index / registration markings to re-register the material after moving the projection image.
I’d split the pattern piece into 4 pattern pieces so that you can line them up and use chalk to draw the cut lines on the fabric instead of cutting the fabric directly, so that you can line up each pattern piece perfectly before cutting. However, this may mean that you need to move the projector & re-align it if you don’t want to move the fabric.
This is almost like exporting a full image with the tiled image rectangles shown on top of it.
Maybe we need to add an export option ‘PDF with registration’. I may need to look up better words for this.
The user would enter the width and length of the repeat, and that would define the width and length of the tile on the image.
The registration marks would be “+” cross marks at each tile corner, or line intersection. The tile rectangles wouldn’t be visible, only the “+” cross marks.
We could set the crossmarks to be a black “+” inside a white circle for easy visibility when projecting.
@DavidDeb What do you think?
Thank you @Sue for your comments. Those sound like solid ideas :+1:
Having the ability to set / display, (perhaps user defined?) registration marks at user defined grid resolution / co-ordinates & offsets, would be of great usefulness, especially for those who have made the transition to projection over paper patterns.
I only make the above-mentioned point because I have no deeper attachment to paper patterns, and really begrudge the time spent on doing jig-saw puzzles with A4 / Letter sized pieces. In addition, the correct archiving of paper patterns is way beyond the scope of my hobby room, and my own special brand of what one may generously call “Tidiness” !
PS: If this is seriously meant as an additional feature, please also consider .SVG format too.
I am using projector mostly and even when working and projecting area is 180x100 cm, I almost always move material on the table. My experience:
  • Lines are way better then crosses to match pieces.
  • Certain overlap is needed too. I use 10cm not to lose to much working area, but it would be easier with more.
I am adding one of my working pdfs
M_S HAKA Jacket in Working Style.pdf (240.6 KB)
Hi @nejcek74 ,
I would be interested in learning of your experiences in ‘projection’, I have just started and use an Epson EB-685W and the < https://www.patternprojector.com > WebApp for the image.
As yet I have not yet really suffered issue with anything nearly as complex and large as your .PDF seems to indicate and I’m keen to learn about this.
