Rotating work pieces for control
Hi folks,
I have been using valentina/seamly for a bit, getting a lot of joy out of it. Now, I would like to post my first question here - apologies if I have missed an already existing answer.
So: I have a pattern with two work pieces. Is there a way to rotate one of the work pieces, so that I can view them next to each other (in order to check that two curves run smoothly into each other, from work piece 1 to work piece 2)?
Any response would be greatly appreciated, flugzeug
Je ne crois pas que l’on puisse frairie pivoter des pièces en entier
Hello and welcome, @flugzeug
Currently, there is no way to do this as a temporary exercise, however, I would suggest that you use the move and rotate tools to move the 2 pieces to an aria outside of your pattern to check them:
This way, when you do alter the angle or length of a curve handle, you will be able to nip over to the moved objects to check the effect immediately in the moved objects.
I hope this helps you :slight_smile:
Salut sofe and Grace,
Thanks for your help! It took me a little while to understand how the move & rotate tools work - now it works and solves my problem!
Merci, flugzeug
