the seam allowance at the bottom of my hems don’t seem to be right.
i’d like them to angle back in so they follow the side seam.
it was working correctly on symmetry before i made some changes and now is
doing an odd angle.
janna jacket.sm2d (27.9 KB)
Can I assume you want the hem look like this:
If so currently the SA angles will not accomplish this. You would have to use a custom seam allowance which is very convoluted to aacomplish.
Hi @emilyli
I know it’s off topic, but I had your pattern open and just an observation… Can I assume your intent here was to show a double notch?
You don’t have to create 2 seperate node points… you can set the notch count to 1, 2, or 3 and it will create that many notch marks.
Changing the width will make some notch types wider as well as increasing the spacing between marks:
thanks. i actually added a notch by accident. but helpful to know that the multiple notches is an option!
