I made some patterns and for some reason I can place a seam allowance for all but one.
For the pattern in the middle, the seam allowance option doesn’t work as I want, It only, colors the object from inside. I’ve redone the object and also I made sure all the curves are clockwise direction, further of that, I don’t know what to do.
What system are you using David? I had the same thing about a week ago - I use Mac OS X Mojave. I couldn’t work out why but deleting the detail piece and retracing it seemed to cure it. I didn’t do anything differently but it just worked. Possibly just ‘one of those things’!
As your piece is a very simple one, it shouldn’t take long to redo it. Hope that works. Doesn’t solve the issue but let’s you get on with the project!
Hi, you seem to have nodes out of sequence. If you send me your .val & .vit files, I’ll fix it for you and point out exactly what I did to get it right
