Hello,
As you can see in the image, the seam allowance is not placed correctly at point A34.
Am I doing something wrong?
I am using this version 0.6.0.0a
Please, post your file.
Rok_Desert-Woman.val (42,9 KB) Linda_Estelle_maat_40.vit (2,0 KB)
I have opened an issue https://bitbucket.org/valentinateam/valentina/issues/686/seam-allowance-not-placed-correctly
I have released a fix. But as you can see you have the same point twice in your list. Just remove one of them and this will fix the seam allowance.
Thank you very much.
Hi all, I have the same problem. I checked my Main path list and believe I do not have any duplicates. Do I have to download version 0.6.0.11a to get the released fix? Thank you.
Show us your file publicly or privately.
I confirm your bug report.
The fix has been released. You can wait new test build on Monday or use the advise i gave you.
Thank you so much for your kind attention and solving the problem! I tried the solution as you advised and it worked! However, I will wait until the new test build- I think I prefer, in this case, the shape of the pattern the first time.
After able to ‘play’ a little bit more with your suggestion, I actually got a better shape for my pattern than the first time!
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
