something is wrong with my seam allowance. not jogging at the right place. what am i doing wrong?
dain jacket.sm2d (104.1 KB) dain 031224.smis (2.1 KB)
Can I assume this is what you want?
If so here’s fixed pattern. The before & after SA’s were not correct from A42 to A38.
dain jacket_fixed.sm2d (101.6 KB)
A42 has CurrentSeamAllowance before and 4" after A74 has 4" before and 4" after A79 has 4" before and 4" after A38 has 4" before and CurrentSeamAllowance after.
how do you do that?
A74 … ![]()
A79… ![]()
A42 and A38 are a normal corners… they can stay at the default
It should be noted that “first edge” refers to the edge (line or curve) before the node point, while 2nd edge refers to the edge after the node point… in a clockwise direction.
