Hi.
I have attached an image. Is it possible to remove that piece of the seam allowance over point B5? The fabric should be folded on line b12-b5, so I want the seam allowance to be shaped horizontally. Do you know what I mean?
Thank you. Monika
Hi.
Thank you. Monika
Ok, I fixed the problem.
It only appears if I make 0,7cm seam allowance or smaller. If I do 0,71 or more, it works
You can see it on my second piece
It can also help to change the seamallowance angle at node B5:
(by length is the default)
That’s odd. The seam allowance width shouldn’t matter… like Pneumarian mentioned changing the angle is what should change the how the allowance is drawn.
Seams like a bug. Pun intended.
I’d be interested in seeing your val (and vit) file(s) if you wouldn’t mind posting them so I could take a look at it, and I’ll look at the code well to see what’s up with the width making a difference.
I just got an idea… it’s always hard to remember what each angle option does. The dialog could use a small diagram of how each option looks.
I concur. This sounds like a good idea!
