Hi,
I just downloaded Seamly after using Valentina for a while. Right away I noticed that everything on the Seamly interface appeared a lot bigger than on Valentina.
That in itself is not a problem but when I open a window, the bottom of it doesn’t show. For example, when I try to change file paths, the buttons ‘Default’ and ‘Edit’ don’t appear which makes it impossible to actually change the file paths.
I can’t drag the window upwards either so unfortunately I’m stuck at the moment. Is there any way to resolve this issue?
What is your screen scale set at? Is it like 150%? I don’t recomend going over 125%… or for that matter it’s not recoomended going over 100% in Windows:
Valentina may be forcing the app to ignore the display scale.
I changed the screen scale from 150% to 125% and everything seems fine now. Thanks!
