Saludos, he tratado de instalar el programa en mi Windows 11, pero no he podido los tengo en descargas, pero no abren qué me recomiendan qué puedo hacer gracias
Hola y bienvenido al foro de Seamly, @eillen
Normalmente, el archivo que ha descargado es un archivo .zip. Si hace doble clic en él, se abrirá en una ventana del Explorador y dentro encontrará un archivo .exe. Si hace doble clic en el archivo .exe, se abrirá y le preguntará si desea instalarlo. Solo tiene que seguir las instrucciones del software e instalarlo.
Hello and welcome to the Seamly forum, @eillen
Normally the file that you have downloaded is a .zip file. If you double click on it, it will open up in an Explorer window and inside it there’s a .exe file. If you double-click on the .exe file, it will open it and ask you if you would like to install it. Just follow the software and install it.
If you downloaded the app directly from Github you should have a folder with the version number:
When you open the folder there should be a Seamly2D-windows.zip folder in there"
Double clicking the zip file should extract the Seamly2D-installer.exe file.
Double clicking the install file should run the installer and install the apps in a folder of your choice.
If that is not what you see or it doesn’t install I would just download the lastest and try that. On my Windows 11 laptop when I download the zip file, and it finishes downloading it automatically opens the browser and extracts the Seamly2D-installer.exe… which I just have to double to click to install the apps.
