Hi @optimusprime93 .Can you show me a screenshot? Or send your pattern file (.val) and measurements file(.vst/.vit), so that I can check what’s happening, please?
Try deleting the 6.2… part, & double-clicking @S_4.
Theoretically, you might want the measurement to be @S_20+@S4 (or something even fancier!) so just hitting OK when you have it selected wouldn’t cut it. Double-clicking will add the parameter to the formula line at the top. When the Formula: result is what your formula should result in, then you can hit OK & expect it to work.
Yes! This was a learning curve for me. You HAVE to double click. Also to delete a line or object, right click and the delete button shows. You can not simply select and hit delete.
