Hello, After registering I have received a link to a zip file that I downloaded and ended up with 2 drives: Seamly2D and SeamlyME. Only I cannot open or install either because I get an error message saying that the “developper” could not be identified and my MAC cannot determine if it is or nor a malware. What can I do to finalize the installation? Thank you!
What to do if Mac says Cannot be opened because the developer Cannot be verified?
To fix the error where you can’t open an unapproved app on your Mac, you have a few options.
- Look for a newer version of the app. …
- Look for an alternate version of the app. …
- If you’re sure you trust the app developer, you can override your security settings and allow the app to install and open.
How do you fix can’t be opened because it is from an unidentified developer?
- Choose Apple menu > System Preferences, click Security & Privacy, then click General.
- You can grant an exception for a blocked app by clicking the “Open Anyway” button in the General pane. This button is available for about an hour after you try to open the app.
Thank you! It worked
