This means, that Linux distributions like Linux Mint or Fedora, who use Flathub by default, offer Seamly2D now as part of their Software Center / Catalog for installation.
Looking forward to your feedback if you are using linux.
Yes, Ubuntu and other like described in the setup you linked also support flatpak/flathub, just needs to be set up once while other distros already ship it fully set up in the default install. I use it also with Xubuntu and it works fine
Is it possible to create a script that would do some of the setup? Specifically the windows installation creates a tree structure of directories including ~/seamly2d/templates ~/seamly2d/patterns ~/seamly2d/layouts ~/seamly2d/measurements ~seamly2d/label templates
Is it possible to build a separate executable package for SeamlyMe so that it could be installed as a stand alone and therefore executed by a user who is not running Seamly2D at the time
Hi @csett86,
Thank you !!! This is so totally fantastic, thanks for creating the Flat pack for Seamly.
Let me know how I can contribute back to you and your favorite projects.
Best,
Sue
