is there a way to select overlapping lines? can’t seem to figure out how to access lines below lines.
Yes. Change the lineweight of the (top) line that you are able to select to something very narrow… and maybe a different color if you need tell which is which. By using a narrower width it should allow you to select the line underneath.
If you created 2 lines with a 0.05mm lineweight you’re out of luck… short of editing the xml file to make the lower line wider.
If it’s 2 curves, you can always teeak the control handles of the top to be able to expose the lower curve.
That being said, there’s really no need to have 2 identical lines or curves… but I know we sometimes do that because we forgot to add a line / curve we need earlier in the history and it’s just easier to create another.
