I can’t build the seamly on Qt. I got the shell32.lib error. Can’t find it
This is most likely Qt issue - not Seamly2D. I build the app almost everyday with no issues… I’m using Qt 5.15.0 with the MinGW 32_bit kit on a Windows 10 laptop.
Need to do some homework as there is not enough info to go on.
- What version of Qt / Creator?
- What kit are you using?
- Have you tried to compile any other projects? In other words is it related to Qt or Seamly.
- Did you do a “clean” install of Qt? I found it best to remove all Qt versions before installing a new one.
- Did you check to make sure the Qt->Build environment is set properly? That is are the correct paths included?
