Suggestion to include Sewing Instructions
Hii. Seamly2D has really made my workflow easier. Although, I would like to know if sewing instructions can be added inside the pattern. This is different from the label. Thank you.
Hi @Funke_Gloria Welcome to Seamly!
That depends on what you’re looking for. If you are wanting to print out the pattern & have the directions printed on it, then the only solution is to use one of the Labels for the directions. If you are merely wanting to keep the directions handy to the .sm2d file for future-you, you can use the technical details field of the Pattern Preferences.
Otherwise work is being done which will some day allow putting whatever text you want on your pattern pieces.
Thank you for your response. I simply want to keep the instructions for future-me. I will check it out!
