Download our latest build!
It changes “Flip” to “Mirror” in the Operations tools.
Anyone have any issues with this feature?
Using the mirror functions to make a small grid out of two points didn’t reveal any problems.
The “normal” QT error that some Linux systems wallow in did occur, but that’s normal on this VM, & didn’t interfere with this feature’s function.
What error is that? Can you post screenshots?
I can’t find it now, but I’m certain it has been discussed in several threads now, & came down to a bug in qt.
Bonjour à tous,
Je n’arrive pas à installer cette version.
Voici le message qui s’affiche sur mon PC
Bonne journée
Dialog error translated:
“Windows cannot access the device at the specified path or file. You may not have the appropriate permissions to access the item.”
Sounds like a specific computer issue… like trying to install in a directory that the logged in user does not have permissions for.
Try running the install file as administrator… use the right mouse button menu on the file and select “Run as administrator”.
J’ai à nouveau tenté l’installation et tout s’est bien passé. Merci et bonne journée
