Je viens de créer un patron sur seamly2D. Je souhaite le créer avec d’autres tailles grâce à seamlyme. Je ne suis pas sûre de bien m’y prendre. Est-ce que le logiciel fait pour moi la création d’autres tailles, où est-ce à moi de le faire ?
Est-il possible de transférer un parton créer sur 2D à Me ?
You will need to create a Multisize measurements file in SeamlyME which will store all of the measurement areas, that you use to create patterns, with their base measurements and increment changes per size. Once you have your measurements file created, then you attach it to the pattern in Seamly2D and you use the measurement area name in the formulas instead of using direct values.
Welcome to Seamly, @lola.durand! Reading your post, I find myself suspecting that you did not set up a measurements file before you drafted your pattern.
If this is the case, you will have to set up a measurements file in SeamlyMe, set the file as the relevant measurements file of that pattern using the option in the Measurements menu in Seamly2D, then go back & edit the formulae of your pattern to call on the apropos measurements from the measurements file. Only then can you change sizes by using a different individual measurements file, or by changing the active sizing on your multisize measurements file.
