Unable to enumerate family ' "Artificial Intelligence PERSONAL USE" '
Hello everyone, I just updated the program and I get this error when I log in:
Unable to enumerate family ’ “Artificial Intelligence PERSONAL USE” ’
and when I enter the measurements I get the same thing
Not sure what you mean by “log in”? Normally you just run the application.
The “unable to enumerate family” is generally realated to fonts… although I have no idea why or what font would be “Artificial Intelligence PERSONAL USE”.
The “Qt Unable to enumerate family” warning typically occurs when Qt is unable to find a specified font family on your system. Here’s how to troubleshoot and fix it:
Understanding the Warning
  • Missing Font: The most likely reason is that the font family you’re trying to use isn’t installed on your system.
  • Incorrect Font Name: Double-check the font family name for typos or incorrect capitalization.
  • Qt Bug: In rare cases, it might be a bug in Qt itself, although this is less likely.
Troubleshooting and Solutions
  • Verify Font Installation:
    • Check if the font is installed on your system.
    • If not, install the required font.
  • Check Font Name:
    • Ensure that you’re using the correct font family name.
    • Use QFontDatabase.families() to get a list of available font families.
Hello Douglas, thank you por you reply.
Yes, when I run the application, jeje
When I search for that font on my computer, I get:
Artificial Intelligence PERSONAL USE regular
maybe the word “regular” is the problem :thinking:
I don’t know how to use QFontDatabase.families() . I’m going to try to make a patron and see if that issue doesn’t affect it.
Thank you so much
