Good morning, I have a message telling me that I am denied access to save a measurement file. I had saved it to a new folder to make changes to the measurement file for a specific project. Usually I can update the file, but for some reason on this one, I am denied. I am allowed to make a new copy, but can’t save anything to it. Can anyone tell me what I can do to resolve this?
Hello, @SandraB
Can you send me your measurement file so that I can have a look, please? And the pattern that you want to load it into, so that I can check, please.
Thank Grace, here it is. Bodysuit Florence 2025-06_12-P_5700_v1.sm2d (92.9 KB) Florence Base Skirt Multisize_13-Q and 12-P Base_5805_Hi-Lo_v2.smms (5.4 KB)
It seems that the measurement file is missing some measurements that were used to create the pattern:
I’ve imported them in this measurement file. They’re on lines 36 to 49:
Florence Base Skirt Multisize_13-Q and 12-P Base_5805_Hi-Lo_v2 - Extra Measurements.smms (6.8 KB)
If you add measurements, then it should work.
Ah! Thank you so much! I haven’t used the file for quite a while.
Sandra
