Updated keyboard shortcuts
In putting my Qt build workflow back together I picked something easy to work on… I fixed a bug with a double Ctrl + W key shortcut. I also added shortcut dialogs to 2D and Me. Just made a PR.
about_shortcuts
2dshortcuts
meshortcuts
Oops… posted the wrong ME dialog.
BTW… note the 3 icons at the top of the dialogs. The left one copies the list to the clipboard, the middle one saves to a PDF, and the right one sends to the printer (which can also be used to print a PDF).
The clipboard one needs a little work to format in nice straight columns.
Also Note the shortcuts for the scene modes have changed to Shift + D, P, OR L. The former dev used Ctrl + W for the draft mode…??? Ctrl + W is the standard for closing the active window, or in our case the active pattern window.
