Updating Seamly2D to the latest versions
Is it possible to update already downloaded seamly 2D to the latest version?or am.i suppose to download another one
Yes. You can either overwrite your current version, or install the new version in a new directory (recomended). This way if there is an issue with the new version you can fall back to the older version. I happen to name the folder with the build date so I can load a specific build if a user has an issue with that build. I occasionaly clear out oulder versions.
If you have already installed Seamly, then you can open it, go to Help>About Seamly2d. At the bottom left, there’s a button that you can press to Check if you have the latest version. If you don’t have it, you have the option to download it. It takes under 5 minutes. Once it’s downloaded, it will open up the downloaded zip file and you can close Seamly and install the latest by double clicking on the .exe file. Just follow all the steps. Once it’s installed you can go to the downloads folder and delete the download and open Seamly.
If you have the latest version, the Check will also tell you so, in which case you can exit the About and continue working.
