Weird seam allowance angle
How to fix the seam allowance angle at point A42?
I tried all the angle option, no change. It looks OK if I use the default 1 cm, but I want the lower edge to be 1.6 cm.
I hope it is because of mistake I made, not a bug.
Butterfly Male M - Leather Biker Jacket 250704 040.sm2d (85.9 KB) Butterfly Male M.smis (2.8 KB)
I gave it a look. I could well be missing something, but I don’t see any problems on the drafting side. I think it’s a bug, probably having something to do with the way the curves interact.
I do think that if you want the Jacket to fit a range of sizes, more of your formulae will need to be updated to equations with variables, not numbers.
@Douglas will be by some time with further enlightenment.
Yes, I’ve also had a look. If I change the bottom curve to the default seam allowance, it works just fine:
@Douglas will have to have a look. :slightly_smiling_face:
Douglas had a look. :slight_smile:
Generally when the SA does weird things with curves involved I look at the control points.
This doesn’t work:
BTW… 180 + 0 is redundant.
This works:
Why the control point at A37 is affecting the SA is a bit of mystery to me, but I suspect it has to do with the curve is reversed and / or point A42 is a point ON the curve, not an endpoint.
Note: Since I’m going to assume that seam A42 to A37 is to match the Back Lower piece?
It’s unneccesary for the seam A42 to A37 to be perpendicular to A26 to A37. What matters is that the angles at A37 of the 2 pieces add up to 180. The same can be said for the seam at the top. The length of the control point at A26 can also be 0.0.
Changing the length to 0.0 at A26 produced another anomaly:
Which is another thing I look at with curves in the main path: Sometime rotating the order fixes the problem… such as it did here:
Thanks, this solves it. I just need to adjust the control point length at A37 a bit.
BTW… 180 + 0 is not redundant for me. It prevents the angle to change when I manipulate the control length by hand. I purposely make it perpendicular to prevent a sharp pointy turn when than piece it unfolded, it is a matter of design choice.
Holding the shift key when you move the control point does the same thing. :slight_smile:
To formulize the CP to stay perpendicuar I’d use the angle of Line_A2_A37.
With that short of length it’s not going to matter… especially if it’s getting stiched to a lower piece and the yoke. More than a foot away you’ll never see it. Heck you can hardly tell on the screen zoomed way in there’s a difference. The difference between the 1.1071cm and 0.0 CP length is about the width of a #18 sewing needle.
I’m making 3D model. Yeah, it subtle.
I wouldn’t call that subtle… IMO you’ll need a longer CP length than 1.1071. I’d try something more like 4-6cm. Which BTW also seems to solve the orginal problem.
