Zoom % box increment button does not perform as expected
In the zoom percentage box, clicking the increment button works for a few clicks then does not increment the zoom percentage any further.
1 - click repeatedly on the zoom percentage increment button, the zoom percentage will increase with the first few clicks (usually about 3) and then stop increasing
2 - type a new zoom value into the zoom percentage box or press the zoom in button the zoom percentage increases by the expected amount
3 - click repeatedly on the zoom percentage increment button, the zoom percentage will increase with the first few clicks (usually about 3) and then stop increasing
The zoom decrement button seems to work fine in all circumstances.
I am using 2024.8.5.155 on an Intel Mac running Sonoma 14.5
(I found that typing the percentage symbol gives very strange behaviour in this forum post, although it works fine in the heading)
Confirmed… and fixed. Not sure why, but the spinbox did not always like to increment by 0.1%… which is kind of small anyways - so I changed it to increment by 1% and it’s fixed.
I used 2 of them above no problem.
Thanks for the speedy response
I was already working on a different issue in the Property Editor, so I just checked that indeed the incementing the spinbox was not working correctly, Tried a few different things and found that it just didn’t like the 0.1… which is strange because it had no issue decrementing. :thinking:
Should be fixed in this weeks or next weeks release.
