Drawing Curves?
As I responded to this question over here:
Basically a curve is a close-enough-to-infinite series of points on a curved path. In order to trace the points of the curve, click on the curve. If the arrow on the curve is pointing against the trace direction, hold shift while clicking on it, or manually select “reverse” in the piece properties dialog.
